CharlesinGA
Jul 21, 2018Explorer
dotcommer wrote:Dog Trainer wrote:
On my 2016 Chassis I found the CHF using the Hellwig extensions, a Hellwig rear stabilizer bar and the Saftey steer to be a great upgrade no more push during windy days and no being tossed about when passing or being passed by a Semi.
Thank you for the info, what was it like prior to getting all that work done? And what did it end up costing you?
What is CHF ? I’m a newbie
CHF stands for Cheap Handling Fix. The anti-sway bars that Ford installs have two holes in each end. One right at the end, the other a little bit away. Moving the rods from one hole to the other makes the anti-sway bar act stiffer, helping control roll as if you had installed a heavier bar.
Charles
