wildmanbaker
Jul 22, 2018Explorer
Dog Trainer wrote:
CHF is Cheap Handling fix. My costs were at about$1300.00 and that ncluded the Install of the rear sway bar by a local shop. I might also say that a front end alignment by a shop that knows how to set up a MH may also provide significant benefits. The Ford people do not align them for the end product only for the standard weight chassis that they are selling.
OK.... Enlighten me, what is the difference between an empty front end alignment and a load front end alignment. Remember, the F53 chassis all have a straight axle, and caster and camber does not change with weight. Keep in mind the increasing front end caster, also decreases the wheel cut, or how sharp you can turn. Granted, if Ford did not do their job, it will not handle good.
