Kayteg1
Aug 10, 2015Explorer II
How often do you need to pump your tires?
Almost all my vehicles need it once a year.
I usually air them up in fall, when temperature drop adds to lower pressure and even if they loose 1 or 2 psi by spring -warmer weather compensate for it.
Worse come to worse, truck stops have air hose with 150psi +
If you really need air compressor, read cut-in pressure as this is more critical than cut-out pressure.
If 120 psi compressor cuts-in at 85 psi, you will "never" get 90psi in the tires.
38,766 PostsLatest Activity: Jan 10, 2026
