pnichols
Aug 05, 2018Explorer II
It depends upon how small, compact, and space-efficient you want your RV equipment to be.
We have found the best at the above to be this one: https://www.amazon.com/Weber-1141001-Go-Anywhere-Gas-Grill/dp/B00FX3MH1O/ref=pd_sim_86_6?_encoding=UTF8&pd_rd_i=B00FX3MH1O&pd_rd_r=P15QC00NEH5KHAA74BMS&pd_rd_w=ktyTu&pd_rd_wg=j6cc7&psc=1&refRID=P15QC00NEH5KHAA74BMS
When closed up tight, a couple of the 1 lb. propane bottles can even be stored right there inside held tight between the lid and the grill. It of course has a built-in pizzo-electric starter, so all you need to do to BBQ is grab the folded up grill and take it to a flat surface, open it up, use the built-in hooks to clip the lid to the back to block the wind, screw on one of the propane bottles stored right inside, set the regulator dial to "start", and hit the igniter button.
Our RV even came with a small table that can be clipped onto the rear bumper for holding this compact BBQ if we don't want to use a free-standing outside table.
We also bring along a full-size a propane firepit so we can sit around a warm fire to roast stuff in fire-restricted areas.
