Tom_Barb
Oct 24, 2018Explorer II
Trackrig wrote:
As a DP owner, IMHO:
1. DPs ride better because of their air suspension. I don't think many / any gas MHs have air suspension.
2. DPs are quieter when driving because the engine is in the rear.
3. When running the generator in very hot weather for the A/C at night, the A/C is in the front and the main bedroom is in the rear - quieter.
4. The gasser may get slightly better mileage, but not by much. In general you're working the gasser engine a lot harder than a diesel works, but the diesel is usually in a heavier MH.
5. Also, because the DP has more weight you won't get pushed around in the wind or by trucks as much.
6. For going up hill, the diesel will do better, but the gasser will surely get you there.
7. For going down hill, I much prefer the diesel due the retarder or jake brake and the air brakes. I've been on downgrades like coming into the Tetons from Idaho that I wouldn't wanted to have done without a retarder and air brakes.
8. Don't worry about fuel consumption. If there's a two mile per gal difference on 6,000 miles per year, what's that really costing you?
Bill
X2
But I would add, the gas coaches are lighter and more affected by the condition of the road surface.
Some do not have independent front suspension, and will wonder when the road is rutted.
38,769 PostsLatest Activity: Apr 03, 2026
