Mr_Mark1
Oct 24, 2018Explorer
A lot of good answers here.
I'll add that I timed the fueling last time I put in diesel at the truck pumps.
This time, I fueled on both sides as I needed over 100 gallons. We have a 230 gallon tank and I put in 159 gallons.
With duel fueling, I was pumping one gallon every 3 seconds. Once I put in 100 gallons, I closed the passenger side fuel and continued filling on the driver's side.
Putting in DEF fluid is a little slower and the pump handle is very sensitive (at most stations I've ever used). Its seems you have to hold the fuel release part of the handle in that 'ideal' place for it not to click off. :R
We have a 16 gallon DEF tank and I put in 10 gallons this time.
Safe travels,
MM.
Safe travels,
MM.
38,769 PostsLatest Activity: Apr 03, 2026
