HARLYGL94ExplorerOct 03, 2014Gas/Elec HeatI have a winnebago outlook 2007 29B and on the thermostat it says gas/elec heat. Does it still use the propane when it is switched to elec? Thank you
pianotunaNomad IIIOct 03, 2014Hi,If it there is a setting that says electric and another that says furnace, then on the electric setting it will use no propane.
Related ContentElec. heat v. Gas heatGas Heater comes on when Elec Heat is used 2008 Fleetwood Excursion 40'Dominic air/heatingHeating element?Outdoor Griddle Heat Issue
