Denver9
Sep 09, 2015Explorer
cgmartine wrote:
Denver9, you said that if you disconnect the fuel line from the main tank, and insert it in a can of gas, the generator will run, which to me, rules out any problem with the generator, including the generator carburator, fuel filter, etc. The problem is likely the line that goes to the tank. That line should not be too hard to trace. By the way, I live over the hill up here in Beaumont, but I am an expat from Hemet.
I tend to agree with you. After using the gas can option, I hooked it back up to the main line and it ran long enough to use up the residual gas in the line and quit. To me that also rules out the prime switch option a few of you mentioned. I think I will just go down and see Jerry in El Cajon as was suggested earlier.
Thanks all for your inputs.
-Denver
