rgatijnet1 wrote:
By the time you take it somewhere and pay their labor rates, it might be easier to just change them out yourself. REBUILT injectors for your engine are less than $30 each, plus a core charge that you get back when you send in your old injectors.
Changing the injectors is not much harder than changing a set of plugs and I think you will end up being dollars ahead if you do it yourself.
There will be no labor costs except for the cleaning and bench testing. Do you know a source for rebuilt injectors? $30 is not that much more than the cost of the clean and test service. Are rebuilt injectors a NAPA or other parts house standard available item?
Thanks.
