PastorCharlie
Oct 24, 2021Explorer
Lancslad wrote:PastorCharlie wrote:
15 quarts of Motorcraft 15/40 oil and one oil filter for my diesel cost about $65.50.
7 quarts of Motorcraft 5/20 oil and one oil filter for my gasoline cost about $35.00
The difference in a diesel and a gas powered RV sitting in a campsite is the difference in the weight of the chassis and powerplant. One is a much heavier chunk of metal. On the road the difference is HP and TQ. Many diesels have less HP than many gasoline; many have more. Most diesels win in TQ. The heavier RV needs more energy to move it. Diesel wins hands down in the noise category; side by side and running the gas engine cannot be heard over the diesel engine noise.
You missed the Fuel filter, possibly the coolant filter and the need for DEF and on newer engines the requirment of an exhaust recirc. There is also the DEF sensor shutdown problem which is not yet solved.
Yes, you are correct. I did that intentionally. I was only replying to the post above mine discussing the cost of an oil change. That is what I pay for my oil changes. The cost will vary depending upon the type of oil filter/ oil and quantity. Labor will reflect whatever one can get by with....it is relative.
