jeromep
Oct 26, 2021Explorer II
RLS7201 wrote:
The torque converter clutch failed and filed the transmission full of shrapnel. The oil was cooked and the front seal failed on the way home, covering the toad with ATF.
Think out the whole concept of what your purpose.
First the ECU would not be happy not finding the E4OD that is was programed to control. That would create a whole new problem as it also controls the engine. My EEC-IV (catch code MOO0) was only used in a 1995 F53.
Then an Allison and an adapter would cost many times more that my old coach is worth.
Then finding a computer that would interface with the 460 and an Allison would be impossible.
You must be really out of touch if you think THREE LARGE for a special tranny such as I ordered is over the top.
Richard
Let's see here, a 460 stroked to 528 is probably putting out 400 horse and 450-500 lb-ft of torque, or are my numbers way too high? Maybe 350-375 horse and 425 lb-ft of torque? It is impressive that you have such a fun engine in a motorhome, but I bet it is a kick to drive.
I'm not surprised that the E4OD gave up the ghost if your torque numbers are as high as I think they may be. It is a stout transmission, but with those possible numbers, it's time was going to be cut short for sure.
3k to have a performance build of an E4OD sounds like a good deal. There is a YouTube channel for Precision Transmission out of Amarillo, TX and they do lots of tear down videos. Just this week they have posted two for Ford 4R100s, which are the successor of the E4OD and have significant similarities. The C6, A4OD, E4OD, and 4R100 are are all related to each other and are great heavy duty transmissions.
A previous poster remarked that the transmission was automotive. Not really. It was always a heavy duty unit for heavier applications, and they have been built by Ford in so many ways to accommodate medium and heavy duty applications, like large passenger cars, all the way to use in the F-series, E-series, and F53 and F59. Ford hasn't used this transmission in a passenger car since maybe the very late 70s or early 80s. After that it was always in a heavy duty application.
