Baja_Man's avatar
Baja_Man
Gauges or ScanGauge II or OBDII Wi-Fi or Bluetooth Readers?
Would like to add a trans temp gauge to my 2005 Ford E450 with 5R110W trans.
Been looking at various options....
1. Gauge with temp sending unit installed at test port. Need to install sending unit and find a place to mount gauge.
2. ScanGauge II OBDII reader. Intstall via wire to OBD input port and need to find a location to mount display box
3. OBD II Wi-Fi or Bluetooth reader that installs in OBDII port and displays to iPhone via an app. No wires to run and no gauge to install.
Questions.....
Do the SGII and Wi-Fi / Bluetooth readers provide accurate trans temps as well as, better, or worse than a gauge with sending unit?
The SGII and Wi-Fi / BLuetooth readers also provide other engine/trans data that may be useful.
  • I bought a cheap Bluetooth OBDII reader on eBay but it wouldn't connect to iPhone. iPhones are very fussy about Bluetooth. Got a slightly more expensive wifi one and it works well.
  • 2014 E450 scanguage II ..bought it for trans. temp...works great ..normal driving I do not use tow/haul ..trans temp normal ..have not tried mountain driving will use tow/haul on down hills and will monitor trans temps to see how high it goes.
  • I recently purchased the UltraGauge MX 1.3 mainly for monitoring trans temp, it took a while but I finally got the trans temp to work on my 2011 E450. The pre programmed Ford settings didn't work, I ended up supplying support with settings that I found on another forum that worked on a 2013. They then converted it to the correct format then I put in those settings.
  • I didn't see anybody mention the Torque Pro App for your phone. It connects to the OBDII port through a Bluetooth dongle. I use an old smartphone with no service mounted on my dash.
    There are a ton of gauges available and styles. There are six or seven different screens I can get to by swiping. It has a code reader and I can wipe out codes. Best app ever.
