Baja_Man
Nov 05, 2016Explorer
battery was tested bad. Replaced. All is well until ScanGauge II is plugged in... and then the lights mentioned turn on.
I believe Scan Gauge II is bad.
When I use the "Battery Boost" in cab, what does that actually do? I used it when my battery wad dead and it assisted in starting my engine. Was the use of it what caused the ScanGaugeII to go bad? It is after I used it that the lights coming on occured.
