smkettner wrote:
Clean up the label and post the actual battery model and brand etc. for best answers.
How does your house battery stay charged? Are you plugged in or solar? Very easy to pass some of this power to the chassis battery.
Depending on the battery and trickle charge it could take a week to charge. Then it is hard to tell if the battery will charge at all. Best to have a 10 to 40 amp charger.
I cleaned up the label. The battery has a red top that says Optima, AGM, High Performance Battery. House batteries do very well because there hooked up to a solar trickle charge. It's taking forever to get Chassis Battery to accept a charge! I'm using a Cen Tech, 50 amp charger! Thanks, John
