kuzined
Dec 24, 2014Explorer
Gen and shore power
Never did it but was told that if the generator is started when you are plugged into shorepower, a lot of damage would happen. Just wondered if that is true.
holstein13 wrote:wolfe10 wrote:Great point. My coach does this automatically. If I turn on the generator while on shore power, the first thing it does is kill the A/Cs, then preheats the generator, then turns on the generator and after warming up, turns back on the A/C circuits.
If you have an ATS (Automatic Transfer Switch) and it is functioning properly, no, a "lot of damage" will not occur.
But, there are less stressful ways to do it. From an electrical standpoint, transferring under heavy load WILL cause an arc as one connection is broken and the other one made. That pits the points. Same reason you turn off the CG breaker before plugging in your shore power cord and before disconnecting-- so you won't arc the prongs.
Also, as with any engine, it is better to allow it to warm up a little before applying full load. The generator is no different. Can you start you car or coach and immediately go to wide open throttle-- sure, but not very good for them. Same for the generator.
Best practices: Turn off heavy loads before disconnecting from shore power. Disconnect. Start the generator. Let it run for 3-4 minutes, then add loads one at a time.
And, when turning off the generator, turn off the loads and let it cool down for a few minutes before shutting off the generator.
