bigred1cav
Jun 04, 2021Explorer
Gen leaking fuel
My 2001 39' Bounder is leaking fuel from the Gen I to date have been unable to find that rascal.
Where do you think it is most likely to be found?
Hikerdogs wrote:
Does your generator have a single fuel filter or 2 filters? Our 2001 Adventurer originally came with 1 fuel filter at the pump, and a second screwed into the carb. Onan later eliminated the one at the carb because after it was replaced a few times the threads would often start to leak.
They came out with a fitting that would replace the filter and remain in place permanently. Later models came only with a single filter at the pump.
wallynm wrote:
X2 and I had onegbopp wrote:
Did you check the fuel hoses and connections? The rubber hoses can rot or wear from rubbing against something.
