bigred1cavExplorerJun 04, 2021Gen leaking fuelMy 2001 39' Bounder is leaking fuel from the Gen I to date have been unable to find that rascal. Where do you think it is most likely to be found?
gboppExplorerJun 04, 2021Did you check the fuel hoses and connections? The rubber hoses can rot or wear from rubbing against something.
Related ContentNautilus P1 has leaking connectionsFuel hose leakingGen?diesel fuel leakLippert faucet leaks, replaced with Moen
