David0725's avatar
David0725
Explorer II
Apr 05, 2016
Gen set service
Other then changing the oil and filters what other service do you do on it? I have a 1994 onan 7k diesel. Q #2 when the get set is running I meter that's pluged in shows almost in the red to the 110 side but pluged in at home the meter shows over to the 120 side. now I sure the get set is made to run 2 A/C but I only run 1. I wont run much more with the meter on the red side.
1 Reply
  • Fuel filter for sure. Check the coolant and replace when the book calls for it. The manual should have all of the maintenance items listed. When you run it be sure to put a good load on it.
