tpcollins's avatar
tpcollins
Gen set won't stay running the year - AGAIN!
Last year the Gen set wouldn't stay running and I tracked it down to a bad circuit board on the back side of the front switch cover. It ran fine all last year after replacing it. Getting ready to take the kids to Yogi next week and when I brought it in the morning and tried to start the Gen it won't stay running.
I've loosened the cover, checked the oil, even unhooked what I thought was the low oil switch wire and nothing helps. Any ideas would be appreciated. Thanks.
UPDATE - I went back out and took a small rubber mallet and lightly tapped all over the unit. Started it and it ran for about 30 seconds and then died. Tried it again and it won't stay running - a tad bit frustrating!
  • Clogged carburetor from ethanol fuel. I guess I don't need to quote your entire post.
    I would try a fuel filter. Mine did the same thing, replaced it and has been running fine since...
