bigred1cav's avatar
bigred1cav
Gen will not crank
Gen will not crank, seems to be no battery current going to it. Wored fine in June when we came west running ac.
  • Have you tried starting directly at the generator vs remote start? Might rule out problem with remote start. As others have suggested - clean the battery terminal and grounds. Also - on most rigs starting the engine places all the batteries on-line which should maximize power to start the generator.
  • Make? Model? I just went through that with my Onan Marquis 5.5BGM. Do you hear anything when you push the button? Clicking? Fuel pump running? First check is battery power. Get a voltmeter and test the battery voltage at the batteries. Should be around 13VDC. If not good, try jumping them with a known good battery, or simply replace them. If battery voltage is good, then test the voltage at the generator. If not good, check all cables/fittings for good connections, tightness and lack of corrosion. Clean all connections if necessary to remove all corrosion and reconnect. If that's all good, then check the solenoid. You can test it by using a heavy cable (like jumper cables) and jumping across the main terminals. If the engine turns over, then your solenoid is bad. If it doesn't, then you may well have a bad starter motor.
    Again, post the make and model and you might get more assistance.
  • Make sure your battery terminals are clean and tight. A little corrosion can make a big difference.
    Also, any grounding wires, make sure they're clean and tight.
