bounder39zman
Aug 20, 2016Explorer II
Overspeed shutdown point is adjustable with small "pot" on control board
but probably not your problem. If this is out of adjustment, usually will shut down on start up, whether loaded-unloaded, hot or cold. Make sure fan/water pump belt tensioner and pulley are maintaining belt tension. Your symptions sound like temp issue. Generac had problems with temp senders, and offered upgrade part years ago...but since they abandoned mobile gen market, dont know if still available or not.
btw, a/c. voltage is also adjustable by "pot" on regulator, but 115vac with a.c. units running is perfectly ok...
make sure you check coolant level at filler pressure cap (when cool!)
not just looking at overflow tank. good luck
38,769 PostsLatest Activity: Apr 24, 2002
