weschaney's avatar
weschaney
General Winnebago mechanical questions
Hi guys, new to the forum here. I purchased a 37ft 1997 Winnebago with a Ford 460 power plant recently and have been restoring it. Was curious if you guys wouldn't mind laying some knowledge on me, I have a few general questions. The generator is a gas oanan 6500. I got it running yesterday and let it run for about 45 min. Is the generator supposed to charge the house batterys? Just installed two new 6 volt batterys and they are drained down to about 10 volts now.
With the generator running the A/C came on, but it does not blow cold, do these units use freon?
I noticed after I park some gear oil leaks onto the inside of the right rear tire, I'm guessing is a bad axle seal. Anyone know what type of gear oil this rear takes? 80/90?
The check engine light is on, but I can't for the life of me find the OBDII port, anyone know its location?
Thank you, Wes
