weschaney
Oct 06, 2016Explorer
Thank you all for the replies, much appreciated.
all outlets and electrical house components work when generator is running, just isn't charging the batteries. batteries do not charge when hooked to shore power either. Ill try to find he converter.
Im checking the diff fluid today, its a slow leak out the axle seal, will replace it myself asap. Is there a parts store you guys use specific to MH's?
will pick up some GL5 today.
The A/C, if the units are toast, wheres best place to find new ones?
As a full time RVer is it best to run the fridge off the LP? or off the batteries? In the dark on how to keep fridge cool 24/7. any insight is appreciated .
Ill keep you guys updated, THANK YOU!
