weschaney
Oct 06, 2016Explorer
RLS7201 wrote:
Your Dana 80 differential takes 75W140 synthetics. There is a tag under one of the cover bolts that will confirm what I said. Ford recommended gear oil change on your chassis at 100,000 miles. Your rear hub seal can be changed in 2 hours or less. Don't get over charged. 96 F53 chassis has the power booster/master cylinder mounted on the left frame rail. 97 f53 chassis will have it mounted on the fire wall.
Dutch_12078 has it correct about your OBD I port. Ford F53s didn't get OBD II until the introduction of the V10.
Richard
thank you, what part store do you recommend to get the seal?
