Coelacanth's avatar
Coelacanth
Generation X
Folks,
As some may know, rodents ate my Onan QG 4000, onboard generator last year.
The cost of repair thru Onan was almost the cost of a new generator. (Heck, they charged $600, just to diagnose the issue.) Therefore, I decided to go new.
The problem is, the generator compartment is open to the road. Therefore, there is nothing to prevent this situation from repeating. So, I’ve, decided to purchase a replacement, but I’d prefer a portable.
The RV is a Holiday Rambler, Augusta, B+. It has dual, roof A/C units. But, only one runs at any time. We never dry camp. In fact we’ve never gone anywhere that shore electric wasn’t available. I don’t foresee needing a generator to run the RV long term. Our previous rig was a Itasca, Suncruiser. The only time the generator was run in ten years was a weekly function check.
Can anyone tell me what size portable generator would serve us in an emergency?
Best,
Jack
  • If you've never actually used the generator you had in 10 years, then I say save the money. Why put out good money on something you have no use for?
  • Rodents ate the wiring and vacuum hoses and built nests under the hood of my 2007 F350. Three times. To the tune of about $400 each time. Fox urine. Moth balls. Nothing helped. Then I found Critter Ridder at Home Depot. Sprayed everything under the hood with it every month to 6 weeks. Never another problem.
  • ArchHoagland wrote:
    Did you contact your insurance company?
    Yes, we got some of it back.
  • 3500 watts , since I assume you have a 30 amp shore power plug.
    One of the cheaper ones that is also an inverter unit, and therefore quieter would be the Harbor freight.
    predator
