From what I've been reading, theres quite a few of us going through this same problem, genset cutting off while going down the highway or once we stop while traveling for a short break.
It could very well be a heat issue causing the problem, because on ours in cool or cold weather, we never have a problem.
Now on holstein genset, it being a 2011 unit & 4000kw, I dont really know that type of engine, but I'm thinking it may be one with overhead valves & rocker arm, so holstein will need to check that & let us know.
On the other gensets, like say the 5.5 or 6.5kw, those engines are the type I call the old L head opposed cylinder twin, where the valves are in the block & just a flat head bolted on.
That design of engine, where the valves are located in the top part of the block & head is flat over top of the piston, its not uncommon for carbon to build up on the flat of the head & top of the piston & after a while the carbon will get thick enough, the carbon surfaces will start to contact each other & result in a knock or clack.
Briggs & Stratton, had an opposed twin cylinder mower engine just like the Onan & was recommended by Briggs to remove the heads & clean the carbon off the head & piston every 100 hours.
The Onan being of just about the same design as that Briggs, I would think would fall into the same type of cleaning process to prevent the knock or clack from the engine.
I can tell you this much, I have an old 18HP twin Briggs mower engine I bought back in the early 80s & a few years back came a slite knock in it & I just let it go. That knock got louder untill it sounded like it was going to blow up, so when I pulled the engine apart, one of the rods the rod bolts were backed out & that resulted from the carbon build up & it couldnt be compressed any further so something had to give up.
Seeing as I have heard, what an electric fuel pump sounds like before it is filled with fuel, would create a kind of light tin like clack if no fuel was in the pump, were as a carbon build up on the head & piston would cause a more deeper & louder type clack or knock.
As far as both those repairs that was made on holsteins genset, that could be chocked up to a lesson learned from it for him or either a letter sent to those repair places & a refund asked for, because all they did was take his money & the problem not corrected.
We RV folks, seem to be sitting ducks for places like that out on the highways, its just unbelievable how crooked they can be.
Neil
