holstein13's avatar
holstein13
Generator Clacking
My Onan 4kw generator has been making a clack, clack, clack noise since I purchased my motorhome in Jan, 2011. I didn't realize what a problem this was until the generator started cutting off after a while.
So now I'm on a 1.5 month tour of the western US and it's important for the generator to work well and it keeps cutting off. Sometimes very difficult to restart and only staying on for a few minutes to hours.
So I stopped by Onan in Nashville and talked to a technician there who said it was probably the fuel pump. He didn't have time to repair it but made an appointment for me in Oklahoma City. The tech in Oklahoma City replaced the fuel pump and the fuel filter but the clacking noise continued. The tech told me that it was probably the fuel line and that the noise indicated that the fuel pump was sucking air. The pump was covered under warranty, but the overtime and travel wasn't so it cost me $450.00 and no fix.
Then I scheduled an appointment at Ford in Phoenix to check the fuel line on my 2010 F53 Chassis. They dropped the fuel tank and removed the fuel pickup assembly and inspected all the connections in the fuel line and did a smoke test and blew compressed air through the lines. They found nothing wrong with the fuel line. That appointment cost me $600 and no fix.
So now I've spent $1,100 and still have a malfunctioning generator. My next step, if I can find a good mechanic, would be to isolate the fuel system from the generator by bypassing the fuel lines and hooking up a short hose from the fuel pump to a bladder of gasoline. Does anyone have any ideas what else I can do to fix this thing? I'm in the Grand Canyon area now heading north through Salt Lake City, then Yellowstone in the next few weeks.
  • Well if it is a metal to metal clicking noise could be anything inside the engine from rods to valves, low oil pressure etc.
    Impossible to tell without listening to it but if two Onan mechanics agree it has to do with the fuel they should have stayed with it until the problem is resolved.
    I suspect they know you are on the road and the easiest way to deal with it is to send you somewhere else it's no fun pulling the generator.
  • Never heard of a fuel pump make a clacking noise. Low oil and valves/rods maybe. And didn't the guy who installed the fuel pump notice the noise was still there?
    Another thought,check the choke.It might have a broken rod and it's opening/closing and making that noise.And it will make the gen shut off. Good luck.
38,706 PostsLatest Activity: Apr 25, 2018
