path1
Jul 08, 2015Explorer
I hit the priming pump button and listen for a little different noise when the pump has done its priming. Then I hit the start button, only cranks for maybe 2 or 3 seconds before it starts.
If I only use the starter button it takes a more time before it starts. Which is extra wear on battery and starter.
My theory is that the gas has evaporated from carb since the last time I used it and needs some priming to get gas to carb in order to start.
Don't know if my thinking is correct or not, but works for me.
38,768 PostsLatest Activity: Nov 21, 2015
