- tropical36Explorer
lamoz wrote:
Onan Genset OBFA R16004 C
Serial #1843854264
"common case of fingeritis" ??
Meaning that someone got their fingers in there and messed things up, either with rewiring, getting the connections wrong,....etc.
and since we don't know it's history..........
My Generac did something similar once and I did end up with replacing the control board. You may also have a separate voltage regulator board, but doesn't sound like the problem, even if that's the case. - jerseyjimExplorerMight be a cousin to "tinkeritis". Never heard of it before, either.
- lamozExplorerOnan Genset OBFA R16004 C
Serial #1843854264
"common case of fingeritis" ?? - tropical36Explorer
lamoz wrote:
It's running :)
cleaned the fuel pump, jumped the solenoid and got it to run. The switch does not crack it and does not will not stop the generator either. I have to remove the #2 fuse to kill it. I removed the connector for the remote switch from inside the RV
now the question is, could it be wired wrong? I know the fuel pump should not be running unless the generator is on. I have a wiring diagram for the generator but i have no idea how to read it.
Sounds like the control board went bad unless it has a common case of fingeritis. - geno39Explorer
lamoz wrote:
It's running :)
If you could give us the model and serial numbers, it would help. - lamozExplorerIt's running :)
now the question is, could it be wired wrong? I know the fuel pump should not be running unless the generator is on. I have a wiring diagram for the generator but i have no idea how to read it. - tropical36Explorer
lamoz wrote:
I used compressed air to clean everything.. Bought new house batteries, i can get it to crank but by jumping it at the switch.. the noise it was making was not that solenoid but is the fuel pump. It's not pumping gas. I checked the hose and is free from obstruction, I sucked on it and got fuel coming out. the white wire coming from the generator the powers the pump is always hot. shouldn't it only supply voltage to the pump while cranking and running?
Take the fuel line off, attach and drop a short one into a milk jug with fuel to see if it'll run that way. - lamozExplorerI used compressed air to clean everything.. Bought new house batteries, i can get it to crank but by jumping it at the switch.. the noise it was making was not that solenoid but is the fuel pump. It's not pumping gas. I checked the hose and is free from obstruction, I sucked on it and got fuel coming out. the white wire coming from the generator the powers the pump is always hot. shouldn't it only supply voltage to the pump while cranking and running?
- B_s_BunchExplorerSometimes you just have to pull it out to get to things. I have had to do that when they install them in a compartment. They cut a couple holes for ventilation and that is all. Larry
lamoz wrote:
can't get under the, it sits on a tray so all see from the rv is metal
I've searched online for diagrams but can't seem to find one :(
Ummmmmm, we had an ONAN in our 87 Pace Arrow that looked impossible until I crawled down under and found a space that allowed me to remove the starter. The problem in my case, turned out to be a stripped plastic gear that made it impossible to engage the fly wheel or whatever. Went to a Cummings Dealer for the part and we began our trip in the afternoon, rather than in the morning.
38,774 PostsLatest Activity: Mar 01, 2019
