lamoz wrote:
I used compressed air to clean everything.. Bought new house batteries, i can get it to crank but by jumping it at the switch.. the noise it was making was not that solenoid but is the fuel pump. It's not pumping gas. I checked the hose and is free from obstruction, I sucked on it and got fuel coming out. the white wire coming from the generator the powers the pump is always hot. shouldn't it only supply voltage to the pump while cranking and running?
Take the fuel line off, attach and drop a short one into a milk jug with fuel to see if it'll run that way.
