burlmart
Apr 25, 2016Explorer
DrewE wrote:
What is your fuel level now? Most RV generators are connected to the tank such that their fuel pickup only goes partway down the tank, and they won't run typically below around a quarter tank.
I would tend to suspect a fuel problem of some sort before the spark plug on the Onan generators. That seems to be more common. Spark plugs also don't tend to die suddenly, in my experience, but gradually the engine runs less and less well.
good info for OP. also...
the toggle switch for most onan's is pressed in at top to crank it up. BUT just as important is to 1st press it in at the bottom and hold for 10-15 audible clicks - this primes the carb w/ gas.
38,766 PostsLatest Activity: Jan 10, 2026
