subcamper's avatar
subcamper
Explorer II
Aug 31, 2017
Generator and Microwave
I searched the forums and found most questions concerning generators were about running an A/C unit. My question is about running a microwave. The posts referring to microwaves didn't go into detail about wattages. I don't need it to run my AC as it is getting pretty cool this time of year.
I just bought the Champion 73536i inverter generator online. I have the Champion 3500/4000 watt non-inverter generator, but I will be going to a vintage racing event at Watkins glen, NY and wanted a quieter generator.
This Champion generator puts out 1700 running watts. My current microwave uses 1650 watts (input). The microwave got dropped yesterday while taking it back into the house and damaged. I will be buying a new microwave and want to make sure it will work with the new gen. I realize I can run the numbers for wattage, but that sometimes doesn't tell the whole story.
I will be running the converter which will be powering a few lights (I converted to LED lights), the fridge board, and the water pump. I am willing to make sure the pump is turned off when the microwave is operated. I'm looking for "real-world" experiences with these types of generators and microwaves. I am thinking of buying a microwave that draws a max of 1200 watts input. A microwave doesn't have the large inrush current of a motor, but it will have some because of the inductors in the circuitry.
So, do you agree that a 1200W (input) microwave should be OK? If not, then do you have any suggestions?
Thanks
Steve
