subcamper wrote:
The microwave got dropped yesterday while taking it back into the house and damaged. I will be buying a new microwave and want to make sure it will work with the new gen. I realize I can run the numbers for wattage, but that sometimes doesn't tell the whole story.
Look closely at the Panasonic 'inverter' microwaves. These microwaves draw less power when set on a lower power level. Typical microwave just cycles the megatron on/off at reduced cooking power. Panasonic gets down to 600 watts before the megatron cycles.
So if you are charging batteries etc with generator just use a lower power setting. If plugged in or no other loads just crank it up.
