Neco's avatar
Neco
Generator Fuel System '95 Rexhall Vision
Hi Folks,
First post here:
My 95 Rexhall Vision with Generac generator is turning over, but won't fire up. It's not getting fuel from the tank. I disconnected the fuel line from the (I don't really know what it is that has the tank hose going in from the right, and a copper line coming out on the left going to the carburator. ) I blew in to the hose, and can hear bubbling, but there's very little resistance, as if the hose is barely in the gas. When I sucked on the hose, again no resistance (I was trying to get some gas to come out). The fuel tank says 3/4 full in the instrument panel. The fuel hose goes in to the tank from the top.
Any thoughts would be appreciated. Thx!
  • Is this a new motorhome to you or have you had it a while? Go to gas station and fill tank up. Is fuel gauge accurate? The rubber hose has dry rotted somewhere and you are sucking air.Replace rubber hose.
  • Was the fuel filter changed lately?
    Was the generator running previously and now it won't start?
