I could use some generator advice. I have a Onan in my class A and when I start it up as soon as it starts to send power to the unit it shuts itself down. So basically as soon as the transfer switch ...
I would think before you go to crazy pulling things I would go back to where the problem began and the "flushing the can". Also reset the inverter. Does the generator actually stop or does it just stop producing electricity. If the motor stops it may be more on that end. If it is more on electric side the motor should run but just not produce electricity.
