I remove the fuel line going to the main tank and insert it into a gallon can of gas mixed with a 1/2 bottle of seafoam or Berryman's B-12 when ever the genset starts to run a little rough the higher concentration of additive cleans the carburetor well. It also shows how many gals per hr I use under load. Once every 4 years or so I also put some Seafoam in the crank case before an oil change. I was surprised at the carbon buildup that I found in the bottom of the drain pan. My genset is 23 years old with 350 hrs on it, so I have to look for ways to use it.
