Peddler95
Oct 29, 2014Explorer
Our generator, air conditioner/heat pumps, and furnace are under the bedroom. Will never have another with the AC/HP under there. The furnace is not real bad and, as we only stay in campgrounds, can't run the generator during sleeping time anyway.
That being said, to your original question, the best way to deal with the noise is with an acoustic barrier, not an absorber. Acoustic barriers are based on mass weight, in the past being lead sheet, now usually loaded vinyl or silicones. Problem is that to have much effect you will need to add considerable weight.
I'm reasonably sure my AC noise is more from vibration of the unit and surrounding panels, and I'm trying to find things underneath that my add to the problem, you may want to investigate things like worn mounts, loose covers, etc. to see if that helps.
