GPWayne
Mar 14, 2016Explorer
I would check the fuel filter and fuel pump, clean the carb and install new plugs. Did you check it under full load after running for 8 hours? (You may have gotten lucky and cleared the crud out.) Sounds like a fuel problem. I take it is a gas genny. Your situation says a lot for running the genny under load each month. No surprises when you need it.
