Mandalay_Parr
Aug 04, 2013Explorer
If the field current is not high enough, low voltage will result.
Don't know all what you did but maybe the field is wired wrong.
Is the field current supplied through the slip rings?
Are the slip ring brushes seated good?
Is the generator running at the correct speed?
Jerry
Jerry
