Old-Biscuit
Aug 04, 2013Explorer III
THE-RV-MAN wrote:
Everything should be at it should. Slip rings cleaned and the genny is running perfect like it should. But still not enough power to go into the RV
It may be running but it isn't running perfect because it is only putting out half voltage.
You need to go back into gen
Check brushes, slip rings, exciter voltage, speed and voltage regulator
Either exciter voltage is low, voltage regulator is not controlling or gen speed is low
