RudysWorld
Oct 09, 2013Explorer
On mine there is a battery in the engine compartment for starting the engine. Then I have 2 batteries under the stairs for the inside house lights etc. I have a gasser not sure if there is a difference. I do have a battery disconnect switch in the stairwell to disconnect the house batteries when storing so batteries are not drained. I would first check for a battery disconnect switch and check if batteries are engaged.
