MountainAir05
Oct 09, 2013Explorer II
Sounds like you have a set/bank of dead batteries. The engine should have at lease two battery and maybe one for the gen and the rest for the coach. Take reading off the batteries. Have you plug it into shore power for a couple days to see if they will charge up. Reading volts from the batteries first. Check to ensure that you have water in each battery if so designed.
http://www.mmbalmainauto.com.au/PDF/State_of_charge_12_volt_batteries.pdf
