FormerBoater
Oct 10, 2013Explorer
JetAonly wrote:
I have a 2000 Dynasty. The chassis battery starts the Generator. If your chassis battery starts the Cummins then it is OK to start the Onan. Check the Positive from battery to genny, Then check the gennies connection to ground. The Onan's +/- connection studs are on the backside of the generator, driver's side.
Don't know if this is your issue, but a buddy with a Monaco coach had big generator start issues and found that the length and size of the wiring from the battery bank to the generator did not meet Onan specifications.
He installed a dedicated battery close to the genny....problem solved.
