prism
Oct 11, 2013Explorer
Mr.Mark wrote:
We had the same problem about 3 yrs. ago. The engine would start fine but the generator would not unless the engine was running.
The service shop said our engine batteries were too low. Changed out the two chassis batteries and problem solved.
I know it doesn't make sense that the engine started but the genny would not. I just changed the 8 house batteries this year with AGM's.
MM.
IF your two 31 series would start the main diesel engine they would also start the generater.I suggest you have a power drop(resistace)
between your chassis batterys and the generater.The new batterys probable had just enough extra umff to override this defect
