gmay's avatar
gmay
generator or electrical problem
I have 2009 Winnebago Adventurer with Onan generator. The generator will start and within 20 seconds the electrical power will kick in from the generator. The electrical power will stay on about 2 seconds, then there is total loss of electrical but the generator remains running. This happens each time that the generator is started.
Does anyone have information that could help with a diagnosis?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    To diagnose you need one of two things,
    A test lamp, or a volt meter
    here is what I;d do..
    I would buld a test lamp.. You can get a rubber lamp socket with leads at most any hardware or electrical store including Lowes and Home Depot.
    Put a lamp in it, small say 15 watt
    Now find your automatic transfer switch, Depending on your RV (30 or 50 amp) it will have wires inside labeled Generator L-1 L-2 and Neutral (Ignore grounds)
    connect between a the Generator Neutral and either L-1 or L-2.
    Start the genny, light should, quickly.
    When the switch transfers light should remain lit
    When power cuts out the light will be diagnostic
    ON- it's the transfer switch
    Off. the generator.
    Shut the genny off as that's as far as this post goes.
  • If its not your transfer switch, then I would suspect the voltage regulator in the gen.
  • Assuming your coach has an automatic transfer system, the 20 delay is common, but the drop out is not and the problem is probably in the transfer. If you are not competent with electrics, best to find someone that is...
    Matt
