tommykelly wrote:
Fleetwood uses a "shedder" that allows only one A.C. at a time to start...(two roof airs on 30 amps and a 5500 Onan).works great
not knowing anything about your unit call the manufacture and ask them if it has a shedder or some other similar device to prevent
both A.C.'s from starting at the same time.
X2 on that. I don't have 2 AC's but it sure sounds like a lot to have both AC's try to start at once. My one AC starting loads the generator a lot. I would never be able to start 2 at once.
At home you have a lot more power available from the power grid to use at a time then you do when using your generator. JMO
