Blaino
Mar 08, 2014Explorer
Generator pull on 95 roadtrek 210 Popular
I took possession of my 1995 Road Trek 210 Popular this past June. It needs quarter panel rust repair on both sides, which is really no problem for me, however the welding work that needs to be done will require the removal of all the back end wood framing and interior wall panels, etc to avoid "up in smoke" syndrome.
I'll also remove the generator as there will be several inches of flooring going back in underneath the whole outboard edge of the generator enclosure along it's entire length where it meets the outer steel skin.... or did.
Why do people allow their expensive wonders to deteriorate this way?
For those who do not know, the 210 of those days was not a wide body, but was artificially extended in the construction process. Road Trek removed the roof in favor of their fibreglass top and then cut the entire back of the vehicle off adding in a trunk below the floor, frame extensions and then a section of exterior steel skin and welded that bit (about 24 inches) to the front and back of the gap created by the extension thereby extending the body for the "Ultimate" Road Trek. After bodywork and some restructuring inside, the work was well nigh impossible to detect. The rear side windows are placed into this patch area and the best way to see evidence of the work is in the drip rail or "rain gutter" around the top of the sidewalls.
I'm a fair mechanic and a top carpenter and wood worker, but the generator pull and related electrical issues are .... worrisome.
Any step by step will be welcome. Pictures? LOL
Also, I am considering dropping the floor there and going back with a deeper, larger enclosure to house 4 or maybe 6 batteries to become part of a storage setup for several top mounted solar panels.... plenty of room for 4 panels of 2' x 4'(or a small helicopter!).
I would like to have sufficient power to run a small efficient A/C unit all night if needed without the generator running/vibrating under the bed.
I plan to get the project underway as soon as winter decides to finish chewing on Missouri!
Thanks in advance for any help or advice!
