Capt.Storm wrote:
Good thought but yep,you're fine doing that.
NO! Wrong answer!!
YOU MUST UNPLUG THE CAMPER FROM THE HOUSE WIRING WHEN THE GENERATOR IS RUNNING. It is required by law, as well as common sense safety considerations. Somebody could get killed!
REALLY.
Here's the thing, power goes out at your house. Maybe it is because a tree fell on the lines. So what happens when the lineman goes to repair that line, grabs the end that goes to your house (after all, it is the load end, no power there, right) and instead finds a hot wire being charged by your generator?
Yeah, he gets electrocuted. And since it is illegal everyplace I know of to hook up a generator to the house wiring without provision for and actual disconnection from the mains, the authorities will track you down and charge YOU with the criminal offense.
SO, FOR GOD'S SAKE (not to mention your own and that lineman), __NEVER__ __EVER__ UNDER ANY CIRCUMSTANCES, __EVER__ FIRE UP THE GENERATOR IN YOUR RV WHILE LEAVING IT PLUGGED INTO SHORE POWER.
Beyond that, even if no lineman gets electrocuted, what happens to your generator when the power does come back on? Odds are good that your generator will be out of sync with the power plant, and you will have instant short circuit, with the little on at your house trying to overpower the big one down at the power station. If you are lucky, circuit breakers will blow before any damage is done. If not so lucky, your generator explodes in flames.
(Yeah, yeah, I know, if the HOUSE transfer switch is thrown, and the house disconnected from the mains, all is well. Similarly, if the OP's motorhome has a transfer switch, he's golden. But the original post showed no evidence of the sophistication of having such a setup. And sure-as-the-lord-made-the-little-green-apples, there will be people reading this thread who AREN'T sophisticated enough to have such a setup and use it.)
