rgatijnet1 wrote:
A big pot hole or other jarring motion could cause the oil level sensor to shut things down. It doesn't mean that the oil level is low but for an instant if it appears that the level is low it shuts the generator off.
I agree with this, especially if this is an Onan Marquis Gold. That's what we have in our Georgie Boy motorhome.
I noticed it would do this more frequently if the oil level dropped a bit, so I was always careful to top off the oil in the generator before every trip. I also noticed it was most likely to happen when travelling in hot weather, above 85 degrees or so. It never happened when the rig was parked.
I was using the multi-viscosity oil recommended (I don't generally use synthetic oils, just dino oil changed regularly)  because we camped in early Spring until late Fall, and occasionally in the winter here in the Northeast, so I liked the extended cold temperature operation the multi-vis oil provided.
However, on a lark, at the pre-summer oil change, I filled the crankcase of the generator with the straight 30W oil recommended. I rarely, if ever, have the problem any more. Even spending two months in Florida in the summertime, no issues.  IF it happens now, I know that it's because I've neglected checking the oil level and it's a bit low. I top it off and we're good.
So, if you're using the multi-viscosity oils recommended, try using whatever straight blend oil is recommended for hot weather and see if that helps. By the way, the straight 30W has worked for us even in the Spring & Fall camping as usually it's over 32 degrees when we go camping.
gbopp wrote:
If you come to Pennsylvania, don't plan on running your generator while driving.
Funny you should mention that. While the problem existed in most of the New England states, it WAS particularly annoying when travelling through Pennsylvania. We used to vacation in the Lancaster, PA area frequently when the kids were small, so this was usually my "test area" while working on solving the problem. When I was able to make the trip to PA and back in the Summer without losing the generator once, I knew I had the problem licked! LOL    But Massachusetts isn't that much better!
Good Luck,
~Rick
