hotjag1
Jul 23, 2013Explorer II
Generator quits after 20 minutes
I have a 7500 watt Onan generator. It starts and runs fine for 20 minutes and then shuts off regardless of "no load" or with lights and a/c on. I put on a new fuel filter, and both coolant and oil are at proper levels. Checked radiator temp when running, and it is at about 165 to 175 degrees. After it shuts down, the red light on the start swith flashes 3 times. The label next to the start switch states "needs servicing". Does anyone know what might be the problem, or what needs to be serviced?
